bonding???
18 Nov 2005
Can you bond the bathroom and take the earth straight back to the cu?
The cold water main passes through my bathroom and the copper pipe is connected (at the bottom) with a 10mm main earth to the MET; so I suppose, by chance, it is earth-bonded to the CU... but regardless of this, the equipotential bonding goes to the lighting circuit (there are no other circuits) and the various hot, cold and c/h pipes.
The point of equipotential bonding is that it carries on working inside the bathroom, even if someone hacked about at the cables between the bathroom and the CU.
