    Dismiss Notice
Bosch Classixx 1200 S Express washing machine not spinning
Discussion in 'Appliances' started by kprabucki, 1 Jan 2015.
  1. kprabucki
    kprabucki
    1 Jan 2015
    Thanks Received:
    Devon
    Country:
    I have a Bosch Classixx 1200 S Express washing machine that is going through the washing program but not spinning, I have checked the filter, removed the back of the machine to check the belt is ok, I have manually moved the drum to check it can move, any ideas?
    What I've tried so far?: as above (checked filter and cleaned, removed back of machine to check belt is not broken, have done an empty was at 90. and manually rotated the drum to check it can move freely.
    Help appreciated.
    :mrgreen: although I'm Mrs Green!!
  2. Sponsored Links
  3. planenut
    planenut
    1 Jun 2004
    698
    Thanks Received:
    12
    Country:
    Hi, I am pretty sure that the motor has carbon brushes, and these should be checked. If they are well worn, replacing them could be a solution.
    Worth a look before considering replacing a machine.
  4. Coaster
    Coaster
    1 Feb 2005
    444
    Thanks Received:
    8
    Tyne and Wear
    Country:
  5. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
