Bosch Classixx dish/w flashing light problem
18 Jul 2011
Hampshire
I have a Bosch SRS53C02 dishwasher, that went bang the other day :cry: , It now pulses all the lights and a motor once per second. I removed the controller, and found signs of a circuit board feed-through having fried so I repaired it with the aid of some wire and a soldering iron. however it still does the same thing - i.e. all lights flash once per second, and I can hear a relay ticking and motor running in time to the lights.
Does any one know if this is an error state that indicates a particular problem, or is it the controller processor fried and that's that :?:
It indicates that your pcb is history.
If you decide to replace it I would advise that you check the integrity of the main electrical components before firing up again.
