Bosch D/washer SGS55CO2GB check water not usual pipe block
18 Mar 2008
Guys
You have helped me before so i hope you can advise again. The dishwasher check water light comes on well into a cycle when it appears it cant pump water out.
It starts the cycle just fine, heats up the water no problem but about 20 mins in, it makes a gurgling noise and does not go on any further. Ive had the panels off and checked the hoses. I can see it suck in water fine and it seems to be working just great till it stops to change something from within the cycle (i guess to pump water out) and then it gets stuck on a gurgle.
The plastic matrix (i think thats what its called) the first water channel on the left hand side remains half empty during this gurgle problem, when normally its full to the brim like the channel next to it on the right. Could this be part of the problem?
Any help appreciated.
Well i have found the cause - its a leak setting off the anti flood switch.
I suspect i will need an engineer to investigate the leak or is there anything i can do further?
Thanks.
