    Dismiss Notice
Bosch Dishwasher E04 error code
Discussion in 'Appliances' started by markwidgery, 14 Sep 2020.
  1. markwidgery
    markwidgery
    9 Jul 2010
    12
    Thanks Received:
    Oxford
    Country:
    6yo Bosch Exxcel Aquastar 6.5L repeatedly showing the E04 error. Seems to get most of the way through a wash cycle before error occurs.
    According to advice on this page I checked and cleaned the spray arms, and found nothing blocking any of the holes. I have also checked the drain filter and impeller which is clear. Drain is not kinked and working fine. Turned off for >20m at plug to reset multiple times. When running a test cycle with dishwasher empty I opened to check and noticed that the water is cold even after the detergent drawer has opened, running on an intensive cycle.
    According to all the advice the issue is a faulty flow sensor (like this one I think), but I'm concerned that the water is not heating up at all and if something else is the problem. Any ideas or do I need to contact a pro, or just bite the bullet and buy a new one? TIA
  2. Sponsored Links
  3. sircerebus666
    sircerebus666
    31 Oct 2019
    1,244
    Thanks Received:
    200
    Country:
    The error code does indicate a faulty flow sensor , as you have checked all the arms and found nothing I would replace it
    You will probably find that the cold water is linked to the flow sensor and replacing it will solve this
  4. leegsi
    leegsi
    5 Feb 2016
    119
    Thanks Received:
    12
    Country:
    Check its draining away ok.
    The waste can get blocked where it meets the rest of the plumbing.
Loading...
Share This Page
