Bosch Dishwasher E15 diagnosis
16 Mar 2015
Sussex
Morning Peeps
Have a Bosch Dishwasher SBV69M00GB that has been leaking a little while and causing the E15 error.
Have installed a new sump seal thinking that was the cause but now have made closer inspection and now thinking it might be the water diverter valve?
Does this look like the cause?
Cheers muchly N
Or the float switch, or is that what you mean.
Where the leak is coming from is the query.
Main cause of the E15 seems to be caused by failure of the sump gasket so replaced this with part 12005744 but dishwasher still leaking. So went under and videod and from the looks to actually be dripping and coming from I understand to be the diverter valve?
I'll see if I can get a better close up and remove the sealant left by the engineer.......
Cheers
@beard79 did you ever find the cause? Got a leak in the identical position on our Siemens which has the same internals and that isn't the main sump either. Thanks.
