Bosch dishwasher SGS55C02GB lower arm not spinning
9 Feb 2013
Anglesey
Problem as per title. I have checked that the arm is not blocked, have cleaned all components internally and have replaced the heater/valve assembly for a new one from Bosch, but lower arm still doesn't spin (although water comes out of the arm). The top arm spins fine. I noticed in the heater I removed that one outlet disc was mostly open while the other (presumably for the lower arm) was only partially open. This may explain why the lower arm is not spinning but some water comes out of it (the pressure is insufficient because the valve isn't opening fully thus restricting the flow. My understanding is that as one valve opens fully, the other should fully close, and this cycles at @ one minute intervals).
Does anyone know what might be going wrong? Is whatever controls the valves malfunctioning (possibly a logic board)? Is there a way to test the valves are working properly in the heater (just in case the new unit is faulty, and also to see if the old one was)? Also I'm wondering if the machine has to be reset after replacing the heater; if so, what combination of buttons do you press for this specific machine?
And in case you're wondering, there is a button for upper rack only which lights when it's pressed, but the lower arm doesn't spin even when that light is out.
Any help would be greatly appreciated. If it's likely to cost much more to fix, I'll reluctantly have to get a new one. Just can't do without one though; I'd forgotten how awful washing up by hand is!
Regards
Neil
