- Joined
- 11 Jun 2010
- Messages
- 2
- Reaction score
- 0
- Country
Good morning one and all, I have joined due to a dillema!
I have a Bosch Classix (older model 10yrs) no display just four wash option buttons on right hand side.
First it wouldn't drain, I couldn't find any info on getting at the drain pump...
So I thought if it's broke I have nothing to loose - I took it apart, well at least after solving the puzzle I got the bottom plastic case off - giving me access to all the components. I located the pump removed it, found it had a piece of china stuck in it - removed - reassembled (carefully noting where everything is supposed to go).
Of course an expert will now be at least chuckling - as I now realise all I need have done was to remove a single screw on the inside to clear the pump.
What's done is done - it drains fine, (I threw a bucket of water in) but it won't fill - seems the inlet solenoid isn't receiving power - I put a test meter across the terminals.
I read somewhere about a flood sensor.
Any ideas? it WAS working fine before this. Can't afford a new one!
Thanks in advance - Graham
