Bosch Exxcel 7 Washing Machine not fully draining after cycle. No error code showing and have cleaned filter and drained at the base of machine. Any suggestions?
You say it is not fully draining? Do you mean there is a small amount of water left in the drum when you unload the machine? It could be a simple partial blockage of your waste plumbing. You could pull the machine out and see if it will drain OK into a bucket. If it does not drain properly into a bucket you might find there is an obstruction, such as a rubber band caught in the pump.
