BOSCH EXXCEL 8 WASHING MACHINE DRAIN.
20 Sep 2017
Hi, My washing machine is not draining. The filter has been cleaned, the drain tube lets out only a dribble and the impellor is spinning. I can't see where the water goes from the drum to the impellor. Any advice would be appreciated.
8 May 2017
There is usually a rubber pipe that goes from the drum to the pump. Only visible from beneath ,or the rear of the machine usually.
Is the drum full of water ?
20 Sep 2017
The rubber pipe was just a dribble. However now fixed. There was 20 centimes and 5 centimes in the coin trap but the reason I couldn't see the drain hole was because it was covered by 2p coins blocking the flow completely!
