Bosch EXXCL 1200 Express - Conditioner not added to rinse
1 May 2006
Bedfordshire
During the rinse cycle not enough water, if any, goes into the fabric conditioner section and the end of cycle there is still conditioner in drawer.
I have added water into conditioner drawer section and the water syphons correctely out of the drawer.
When using the the freshen-up cycle in which the machine should add fabric conditioner only, water seems to spray into the detergent/powder sections instead. No water goes into fabric conditioner section. This is observed by pulling drawer out slightly and seeing spray.
All other features seem to work correctly. I have cleaned inside dispenser section
Taking the top off, I notice there are 2 solenoid feeds to the dispenser top, feed with black rubber tubing to solendoids at the back. There is also a light grey tube which goes down the front to the bottom of the machine.
Any suggestions please as to fault?
Possibly a blockage in the top part of the dispenser housing. You can buy a new top for the housing or you can take it out and try clearing it manually.
