Bosch fridge LED lamp
12 Jan 2020
Has anyone tried to replace a Bosch fridge LED
The manual states: “Your appliance features a maintenance-free LED light.
These lights may be repaired by customer service or authorised technicians only”
So it seem like it might not be possible, but I'd rather not call out an engineer just for a bulb
Model is Exxcel KGN30VL20G
Thank in advance
Slide the whole plastic cover on the light unit sideways to the left. It will slide about 10mm. Then gently prize the cover downwards using a thin knife blade on the left side. The cover is fastened in using small indent pieces. I have done this ok without breaking anything.
Thank you so much for this information. I’ve sent for one using the code you supplied. Would never have found replacement without help. Absolutely crazy that Bosch recommend that you need an engineer to replace the light!!!
Thanks to Guy for the information my Bosch KGV36V32G/06 LED just started flickering.
