Hi everyone, new to forum.
We have the above system installed, and would very much like to add weather comp. 2 heating zones, + 1 for the Megaflo cylinder. I have spoken to WB technical regarding the Greenstar Sense II, they basically said forget it, not possible in your system due to the motorised zone valves and lack of optional diverter valve.
I then came across this fantastic thread :
www.diynot.com
which was a real eye opener. Small problem, its about Vaillant boilers....
So, is it possible to do something similar with this WB boiler, perhaps using the Greenstar Sense II as the comp interface, or even some other 3d party component ?
Vaillant heat only boiler + switched live thermostats + weather comp?
Hello lovely people I have Valiant 428 heat-only boiler on S-plan Plus pipework. 3 heating zones are controlled by 3 Nest thermostats via Switched Live Terminal 4. System water temperature is set at constant 45C. Lovely config. Now can I add Vaillant eBus Weather Compensation product (VRC...
www.diynot.com
