Hi All
i was wondering if you could help.
The above named/numbered Exxcel (2 - 3 years old) starts its cycle for about 3/4 minutes then stops, the water that is in the base is also cold.
The impellar rotates with a slight resistance and all the filters are clean.
I have removed and tilted it to re-set the float level indicater and the inlet feed pipe is okay with adequate pressure.
Any Ideas please as to what is wrong or if it is worth repairing (thats if I can find a repairer)
Thank you.
Thank you.
