My 4 year old Bosch washing machine has suddenley decided not to spin! The rest of the wash is fine, and the water is draining away. I have tried to do the spin cycle only, and still not spinning fast. Clothes coming out dripping wet! Help![/b]
have you tried it with a different load?
most modern machines wil refuse to spin if it thinks that the load will be un-balanced. usually bath mats or heavy towels or a dog blanket etc.
Hi had problems with washers in the past not spinning on any spin cycle, your problem could be the brushes in the motor worn, my problems always turned out to be some component gone on the circuit board
