I have a Bosch WFK2401 that will no longer agitate or spin. It fills with water empties etc as normal but no agitation or spin.
I have checked the pump, no blockadge etc. Also I removed the back and the belt is fine.
When I selected a spin cycle (9 on the dial), it said it had 6 minutes to go...after about a minute of running what sounded like the pump it changed to 1 minute remaining. At the end of this minute it gave the end of program signal and released the door.
Any ideas on what I should do next?
Thanks,
I did some more testing and plugged the machine back in, set it to spin, gave the motor a couple of hits with a wrench and it worked!
I am now thinking that maybe it is the motor. When it is spinning at 1200RPM there is a sound like a playing card being stuck into the spokes of a spinning bicycle wheel. Also....I could see a blue glow...arcing...in the reflection from the bottom plate of the washer. I am thinking maybe the motor is shot or perhaps the brushes.
Thoughts?
Sorry...I should have pointed out that this washer is in Canada. Hopefully someone in the UK is familiar with this model or type and can help.
Ken.
Thanks,
Thoughts?
Ken.
