Bottom stair riser creaking and floating
3 Apr 2013
Hertfordshire
Hi all,
I've just had a nice new laminate floor laid in my hallway and now the small creak from the first step has changed to a big creak and more movement about 5mm when stepped on.
Unfortunately for me there is no easy access from under neath as instead of plasterboard, there is a wooden strip over a wood panel on the underside of the stairs, then a vertical tongue and groove piece behind the first riser. Very involved to remove!
I can get behind the first step as the newel post is fitted to the second stair leaving an angled edge.
How can I support the first riser to stop movement and noise?
Would it work to insert a suitable thickness strip under the riser from behind, then poly glue in place?
Chris
Unfortunately to do an effective repair job on a closed riser stair you need access to the underside of the treads. I think you'll have to bite the bullet on this one. At least you'll understand why the Victorians often just had plastered under drawings
OP,
you say, the creaking only bigged up after the laminate installation which would imply the laminate is the major factor with the creaking?
a movement of 5mm is significant - if the 5mm is entirely new then i'd suspect that you've done something to the joinery at, or surrounding, the first step.
can you post photo's?
