Bowl &1/2 with high waste, any suggestions?
9 Jun 2009
Yorkshire
Hi Guys
I have a job coming up, kitchen sink to do with a waste that is quite high, looking for options, there is also a washer and dishwasher to contend with, I'm hoping the picture is deceiving and it's not as close as it looks.
If anyone has any suggestions they are welcome, one thing I do know Is that the waste cannot be lowered, apart from maybe slightly we could remove the fall or most of the fall if required from the horizontal section, as a last option but that would only gain us 10 or 20mm.
The waste is bossed into a stack quite high before it exit the kitchen to a high drain outside, the kitchen is lower than the ground outside, (long story short, it's been bodged) it's for someone that gives me work so I cannot just walk away and must face it and find a solution.
Any help would be really appreciated.
Kind regards
Rich
Only solution that will work is to lower the waste to a suitable height, from the picture it looks doubtful you get a waste and trap on the lower bowl, and even line up with the outgoing pipework, never mind getting a fall on it. Asking water to run uphill is never going to end well, if you've a washing machine and dishwasher to go into the run as well, I think you're going to find the sink filling with dirty water on a frequent basis...
If you really cannot get a fall on the pipework, the other option is to pump it back up, have a look at the Sanivite Grey water Pumps.
