Box holes
10 Jul 2006
Cleveland
Can any1 recommend a attachment for SDS hammer stop drill which will put socket/switch box holes in walls made from brick? Theres a few out there but want someone to recommend a decent one which will do job and last a while
or
trazor said:
http://www.axminster.co.uk/product-Armeg-SDS+-Electrical-Box-Sinker-19629.htm
Will these do holes in bricks? Its just been told most will only do soft blocks and the bricks break the attachments, is that true?
Reading the text....
In hard materials such as engineering brick a hard material chisel is available for use in place of the square cutter.
On the same page:
Armeg SDS+Electrical Box Sinker Hard Material Set
As gcol says for bricks you'll need the hard material set, but they still struggle with engineers blue brick (doesn't everything?). The standard tool is OK and certainly work well in blockwork, soft stone and soft brick, main thing to remember is to let the machine do the work - go at it like an animal and you'll bust the pilot bit.
Scrit
