How do you remove Plumbeasy brass push fit tap connectors?
I am fitting a bath at the moment and bought an expensive NoFlames Plumbeasy brass push fit tap connector. 3/4 tap at one end, 15 mm push fit at the other.
The pipe connection proved to be not watertight, possibly because I used a hacksaw and did not cut the pipe off square.
Anyway, now I have put it on, the push fit connector refuses to be removed! The packaging mentions I might need a Removal Pack...
Any ideas? Note that these are not the plastic push fit connectors, where you can ease the clip back and slide the connector off.
Mike
Mike
