- Joined
- 16 Feb 2015
- Messages
- 3
- Reaction score
- 0
- Country
The render above the front window is also partially
defective and the cracks should be raked out and filled prior to appropriate redecoration.
There appears to have been some movement at this point which should be monitored for
any further deterioration and water penetration should be prevented and if possible the
bressumer/lintel at this point should be examined before the render is replaced Hi everyone this is my first post...I am popping my toe in to buying an 1880 miners cottage in Wales ...and the above information if part of the report from the surveyor...
My question is what is a bressumer/lintel and is it expensive to replace , does it present as a warning sign of hidden problems...
Thank you everyone
Thank you everyone
