My garage has a brick outer wall and breeze block inner wall.
In the past someone has a cut hole to the previously solid walls to fit an external door. The external door frame is only the width of the external brick work and is screwed directly into it , leaving the internal breeze blocks and cavity exposed.
The question is what is the correct way to finish doorway so that I cannot see into the cavity. Do I just screw a door lining kit into place?
