british gas c1 boiler wiring(ie worcester)
22 Dec 2010
Bradford
Hi guys,need help on hot water high limit switch & hot water outlet safety thermal cut-out i was fault finding disconnected both now im not sure which coloured pair of wires go to which.Please HELP! :(
Do you have the installation manual? A lot of overheat conns on WB's are orange.There will be a wiring schematic in the manual.I assume you have one,how else would you be able to fault find?
i don't have a manual fault find method visual. original hot water problem check whats in line.The two choices i have are yellow or pink.if any one knows where i can find a wiring schematic on-line for british gas C1 combi boiler.Cheers
