- Joined
- 1 Apr 2016
- Messages
- 13,606
- Reaction score
- 550
- Country
So a tenant moved out last month and I have only had time today to check the property out and there are some small amounts of damage until I saw a wonky radiator.
On closer inspection the bracket holding one side of the radiator was loose and after a slight push the whole brackey fell off. So one one side there is no bracket supporting the radiator.
I placed a block of wood under that side.
I called my letting agent but he wasn't picking up. I believe there is no other damage as the property has been empty for a month now and there are no leaks that I can see.
What else should I check out for in respect to other damage? How do I make sure there are no leaks?
I am not sure if I can find someone to come out. So as long as there are no leaks I am not too concerned.
