bt cable
12 Jan 2010
hi ive brought a house back in may and need to run new cables to tel lines and internet ect
I want to run them under the floor while I get a chance as im guessing bt will run it external around the house.
can some tell on if bt drop cable is correct.
Sorry on my phone
Can someone tell me if the cable I need is called bdt drop cable?
BT use dropwire to run from the telegraph pole or underground to your master socket. From there you can run your own extensions to wherever you want using CW1308 cable internally.
