A similar post to many seen on here but none quite answer my question.
Your help would be much appreciated.
I am upgrading the radiators in my living room. I require a BTU of approximately 6000 over 2 radiators. Assuming i have all the appropriate draft exclusion/insulation/boiler power my question is this.
"If the BTU rating of a single panel radiator is the same as that of a double panel radiator what is the advantage of buying double when typically it is more expensive"
---Logic says to me that if they have the same potential heat output they are going to produce the same amount of heat....no????
