Building out of Reclaimed Stone - Minimum Thickness of Wall?
22 Jun 2009
We are building our extension with an external skin of reclaimed stone (sandstone/gritstone).
Cavity wall will comprise of:
Internal Skin: 100mm blockwork,
Cavity: 100mm insulation filled cavity,
External Skin: Stonework.
What is the minimum thickness the stonework needs to be? I'm wanting to go for around 130-140mm (around 5 inch). Architect says anything above 4 inch is fine, but just want to make sure.
Is 5"/130mm thick enough to meet Building Regs in structural terms?
Depends; if it's coursed stone and fairly regular, 100mm is fine. If the stone is irregular/uncoursed, Approved Document A recommends 1.33 x thickness of normal brick, ie around 130-140mm.
It's nothing to do with the compressive strength of the stone, it's the potential lack of even bedding.
Thanks Tony.
We are hopefully building random coursed walls, so should be plenty thick enough.
Cheers again,
W.
Please don't do full fil insulation, do partial fill and use SureCav. Get your Architect to consider it.
Hope that helps.
Would I have to use surecav if all my stone was backed off to, say, 130-140mm?
We weren't planning on using 2 skins of blockwork...
Random stone needs a backing block really (or use Surecav as said) except for a single storey maybe. I'm not quite clear on the type of stone you're using?
If its coursed (sawn, or dressed even, top & bottom) 100mm+ is OK, if random, it'd need to be nearer 150mm, & see 1st paragraph.
Like this:
Coursed, but courses not at the same height:
