Bulldog TRV heads
18 Nov 2015
Dulnain Bridge
Hi there,
I have a problem with the above heads, after a year or so the plastic body under the chrome ring which fixes them to the valve fractures and the heads fall off. I have checked the valves and they are functioning correctly.
Is it possible to buy replacement heads and more importantly for longevity ones with metal bodies and not the plastic. I have six radiators and system was installed by Calor Gas.
markings on the body are Bulldog >gene EN215 with a number 42 above.
I have looked on Amazon, and can source heads, just wish to make sure correct ones.
Thanks in anticpation.
John
Yes the heads are straight replacement. Usually it takes many years for them to get that brittle though. Are you perhaps running the system very hot? (e.g. 80 degrees) as I can't think of anything else that would cause this to happen so fast.
been fitting bull dogs for coming on 20 years and never had them cracking unless kids etc hitting them
System is run consistently at 21.5 to 22 degrees C...
Have to say that I have found similar behaviour on other makes of heads, it is just the Bulldog ones that were fitted to my current Central Heating system.
Does anyone on here know of a metal bodied connector, without the plastic internal parts which are in contact with the metal valve.
As the plastic in contact with the valve after quite a short time goes brittle and falls apart when you adjust the thermostat control.
I have attempted to rebuild some of these with araldite, but this only works for a short period of time. Due to the expansion stress placed on the head when the control is turned.
You misunderstood what I said... Not the air temperature the room thermostat is set to. The boiler flow temperature is what I was asking.
