Butt jointing boards.
30 Jun 2008
Suffolk
What is the best glue for butt jointing two 8" wide boards?
Making a table top from some pine and need to join two 8" boards along the edge. Would dowelling help to keep them from separating once joined?
Dowels or biscuits will align them for glueing-up but won't do that much to keep them together. What does that is having a clean, straight edge at 90 degrees to the top on boyth boards, using a decent glue and adequately clamping the joint while the glue goes off
Foxhole, by 'wood glue' are you referring to the PVA type or something like Cascamite? (Something I remember from my school days many, many moons ago! LOL)
Is 24 hours under pressure long enough or should I leave for longer?
JobandKnock. Yes edges are perfectly 90 degrees and when laid together on a flat surface you can't see/feel the join. By using dowels I meant gluing them in on both sides, not just a tap in fit to align.
Something like gorilla glue or a pva based good quality glue, some will set very quick so you only need it clamped for few hours.
Dowels will be a bit trickier to align, so biscuits (which have a little bit of play) would suit better.
Managed to joint them using dowels and Gorilla Glue as I don't have a biscuit jointer but thinking now about investing in one.. Got the alignment spot on by using a marking gauge to mark out and precision drill with the aid of a set square and my partner watching I stayed vertical from the side. All clamped up, (got a thin even line of excess glue squeeze out which I wiped away with a slightly damp cloth), until I get home from work tomorrow and unclamp it.
Thanks for all the advice lads. Much appreciated.
If by Gorilla Glue you mean the transparent brown stuff (polyurethane) then for future reference you're better off leaving the excess glue alone until it cures then scraping it off with a card scraper etc - if you really need to wipe it while wet then iirc you need to use isopropyl alcohol (or meths - can't remember which as I always leave it to dry).
The real trick with these sort of joints is getting the faces to be glued really good and flat so that when you present them to each other as a dry fit there's no gaps (looks almost seamless), then you need to get enough clamps on them to not only hold them together but also hold them flat and perfectly aligned.
Glad to see that you were successful!
Gorilla Glue shares with most other PU (polyurethane glue) the trendency to foam. This can be an issue as it is often a bugger to remove the dried foam sufficiently well that light marks become visible when finishing, particularly staining. A recent type of glue on the market whicjh is more manageable and sets quickly without foaming is D4 PVA, like this one from ToolStation. Like PU glue it is suitable for use outdoors and it can be used for tasks where PU would cause problems such as glueing T&G plywood or chipboard sub-floors (PU tends to blow the joints open a bit). As far as biscuit jointing goes, if you are jointing on the flat (i.e flat boards) and already own a router a cheaper solution is the biscuit jointer bit set. It isn't as versatile as a biscuit jointer but it is a useful addition to a router kit.
Posted for information
Chud, the fact they were perfectly flat edged and mated perfectly gave me the confidence to try, lol.
As I don't have sash cramps I made my own cramps by screwing down two straight battens, further apart then the jointed boards, and made 4 sets of wedges to tap in once the joint was made. I ensured they stayed flat by constantly checking along the length with a steel rule across the full width and then a final check when the glue was dry before knocking the wedges out. The top now sits resplendent on a kitchen 'chopping block' style table. Partner is over the moon with the result. :-)
Are you familiar with "centre points"? (Do a Google Image Search.)
Drill holes on one side, fit centre points, push pieces together, other side is now marked.
Years ago I saw a tool that solves the other problem, i.e. holding the drill straight. Here are some approximations:
http://www.ebay.com/itm/Wood-Drill-...ool-Jig-Dowel-Hole-Center-Guide-/222295146901
http://www.wolfcraft.com/en/products/p/dowel_jointers/1_dowelmaster/s/p/
The thing I remember had a handle like the second link, but had a twisting-centering action like thr first link.
You can reduced cupping tendency in table tops by screwing and gluing a sheet of mdf underneath .
