C/H issues....
28 Sep 2007
Morning all, two central heating issues...
1) Radiator in the spare bedroom has got an inch of warmth left at the bottom and I can't bleed it because the valve has been scalped - so the key just spins. I'd be much obliged if some one could tell me what I need to do in order to isolate this radiaor so i can take it off the wall and try to dig out and replace the valve.
2) The shoulder above my central heating pump is oozing water, can I solve this myself or do i need a pro in? I guess it needs a new seal, but I'd need to drain down the c/h surely? Or can I fix it with some sort of sealant?
All help gratefully recieved. Thanks.
1 turn the rad valves off..undo nuts and drain water into tray. take rad off etc etc
2 .shoulder ?...large nut near pump ?....some times you can undo it a bit and then retighten it
shoulder ?? do u mean elbow? does it have nuts on it photo would be nice
its probably where your system is sucking in air
