Can anybody assist in explaining how to drain my C/H system. I do believe I have an immersion cylinder with a metal coil inside which warms the water. A 22mm pipe comes from the top of it, whilst the C/H pipes enter from the side. I have a header tank in the loft, old Baxi boiler, run by a British Gas timing system(with no manual). I can only see one actuated valve to what it's doing I'm not sure. I will have to remove the leaking shut-off valves above and below the old pump, so isolation might be a problem.
