Yes, that's the theoretical problem, but it doesn't alter the fact that what matters is the (absolute) voltage supplied to the load and that (given the wide range of potential source voltages) the VD within an installation is an essentially useless indicator of that. The only certainty about the 5% recommendation is that it means that the voltage supplied to a load should never be below 205.39 V.The thing is though, electrical installations typically last many decades. you might find your supply is towards the upper end f the permitted range today but it's anybody's guess if it will still be at the upper end of the range in 30 years time.
I would say the following:
- I think one should question to what extent we need/should take into account things that might change in the (possibly distant) future, particularly when we don't seem to do so in relation to things much more important than within-installation VD. If, at a certain point in time, TN earth has a very low Ze, we will accept a circuit as being satisfactory/'compliant'/'safe' if the Zs at that point in time is only just over the minimum required for ADS with the OPD in question - yet, in "30 years time" (or even 'tomorrow'!) the Ze could rise and render the circuit 'non-compliant' because of its Zs. If we took into account concerns such as you mention, we would presumably require that the Zs was sufficiently low for it to remain below the permitted minimum even if/when the Ze rose to its 'permitted maximum', wouldn't we?
- I also wonder, essentially for reasons I mentioned in my last post, whether we really need to be concerned at all about within-installation VD. Eric often talks about problems with fluorescent lighting when the voltage supplied to it is low, and I don't know how real an issue that actually is, but with that one possible exception I struggle to think of likely situations in which within-installation VD would (within reason) present any real problem at all.
- Hence, particularly given that, for T+E >1mm², R1+R2 will always be greater than R1+Rn, I would suggest that if Zs is (currently!) 'compliant, then one doesn't, in practice, really need to think about VD.
