Can anyone tell me if it is possible to wire a 8.5kw shower using 6mm T/E. The length of run is 5 metres and is clipped direct also can you tell me the mcb size. Cheers
40A MCB (shower will use 36A @ 230V). 6mm cable hasa max on 46A so it can be used, however i would recommed using 10mm incase you get a more powerful shower in the future
