I currently have a radial circuit from the house to the garage consumer unit. It feeds a single socket and the lighting. As it's only 1.5mm and I want to add more sockets, I'm considering adding a second radial. Looking at the existing 1.5mm installation, a twin and earth runs from the house consumer unit up into the loft space, across the loft from the front to the rear of the bungalow where it connects to the armoured cable via a junction box. The armoured cable from the junction box to the garage is about 8 metres.
At this point in time, I'm just weighing it all up and would appreciate your advice. The total distance from the house consumer unit to the garage is about 20m. Was thinking of replicating the installation method used for the current installation, that is, twin and earth from the consumer unit into the loft space junction box connected to the armoured cable running to the garage.
As regards what would be used off this circuit, this would be a table saw at 1850 watts, track saw at 1200 watts, a router table at 2000 watts and a mitre saw at 1600 watts. As I would be the only one using this equipment, only one machine would be used at any given time, except for a 1400 watt dust extractor which would be activated when these are used.
Given this, what would be the most suitable size of cable to use from the house consumer unit to the loft junction box, armoured cable and cabling from the garage consumer unit to the individual sockets?
