CABLES
27 Aug 2007
Hampshire
NEFF oven (4.6KW) Instructions says that the connection can only be made using mains connection cable not lighter than:
H05RR-F 300V/500V Rubber Flexible Cable
H05W-F 300V/500V PVC Flexible Cable
NEFF Hob (6600Kw) instructions say use HO5W-F or higher
No size of wire is quoted.... I assume Oven size has to be 4.0mm min
and the hob has to be 6.00mm min.
I cannot find any source for these diameters yes 2.5mm is available.
Im I missing a point or is there an English equivalent to the cables
Thank you Luminaire....Pray tell me how did you arrive at 4.00mm for both appliances..I was under the impression 4.00mm only covered up to 6000 watts or does the cable you have suggested cover a higher range.
Sorry just reread the blurb on the cable you information you suggested its good for 35 amps..so Thank you very much
