    Dismiss Notice
Cambelt Timing Question (2.5 Dci Master/Movano)
Discussion in 'Car Repairs / Maintenance' started by HuggyBidston, 10 May 2018.
  1. HuggyBidston
    HuggyBidston
    18 May 2017
    5
    Thanks Received:
    Country:
    Hey folks,
    I've got a 2.5 dci Master and it needs a cambelt. I've found one poor video in Portuguese on YouTube which isn't a great deal of help.
    I've read a few posts from people who have said you must use a locking tool. Is there any reason why I can't mark cam/crank cogs with tippex like ive done on every other cambelt I've changed over the years ? The kits expensive and locks the crank and cams, but as log as they don't move , what do I need a special tool for ???
  2. Sponsored Links
  3. Burnerman
    Burnerman
    7 Feb 2008
    21,224
    Thanks Received:
    4,105
    Northumberland
    Country:
    I'm not absolutely sure with this engine, but if it's the same as the 2.2 the crank pulley isn't keyed onto the crankshaft which is why the crankshaft must be locked in position and likewise the cam shafts.
    Therefore your time honoured principle of dabs of paint doesn't apply, unfortunately, which we've all relied on dozens of times.
    Honestly I'd leave this job to someone who has done it before.
    John :)
  4. Belle427
    Belle427
    16 Jan 2006
    2,930
    Thanks Received:
    280
    Newport, S Wales.
    Country:
    I’d always advise using the tools if available and not too expensive, saves a whole load of grief sometimes.
  5. Mursal
    Mursal
    23 Sep 2010
    2,203
    Thanks Received:
    483
    Country:
    Ireland
    I saw one lad changing all the old tensioner's first. Then he split the old belt in two with a knife leaving half in place (now a narrow belt) and pulling the outer half off. Popped the new belt on, before cutting the inner narrow strip of old belt off, meaning the timing could not slip.
    But it wasn't his first time doing it and the engine was out ..............
    Room is extremely limited
  6. Sponsored Links
  7. DaveHerns
    DaveHerns
    11 Nov 2009
    2,583
    Thanks Received:
    207
    Country:
    Timing could still slip if the crank pulley is loose and not keyed to the crank.
  8. Mottie
    Mottie
    27 Feb 2017
    7,856
    Thanks Received:
    943
    Essexshire
    Country:
    If it’s got a keyless crank pulley, dab a dot of tippex on the flywheel instead, even if you have to take the starter out to do it. A lot cheaper than buying a tool you're only going to use once.
  9. HuggyBidston
    HuggyBidston
    18 May 2017
    5
    Thanks Received:
    Country:
    Update: I ended up buying the tool which was 40 notes and to be honest I could easily have fabricated it myself , but nevermind. The crank locking pin didn't fit so an Allen key did the job perfectly well. Took my time and double/treble checked everything. Did a quick prayer before starting it and it's all good. Total cost Inc tool , pulleys , tensioner and belt was £130 which was far better than the £400 I'd been quoted to do it.
  10. Mottie
    Mottie
    27 Feb 2017
    7,856
    Thanks Received:
    943
    Essexshire
    Country:
    Yep, very satisfying when you do something like this yourself. Well done. Sounds like you could have got away without the kit though and saved yourself an extra £40. :cautious:
Loading...
Share This Page
