Hi folks ...
Not sure if this is the right section to post in but hey ho..
I recently added a power supply/battery charger to my campervan electric 240v hook up. This allows charging of the leisure battery when hooked up and runs the 12v electrics.
Problem is as soon as I flick the MCB switch the charger/supply is connected to it trips the RCD (60A 30ma RCD)
I've checked and double checked all connections and they are correct. All the rest of the circuits on the consumer unit work fine.
If I remove the charger/supply and plug it into the ring main at home it works absolutely fine - although I only have an MCB consumer unti at home.
Any ideas?
Any ideas?
