Can I Do This ? If Not - Why Not ?
15 Oct 2005
Cheshire
I have wired several lighting points in this way so far but this is not the way the majority of web sites state it should be done :
From the main lighting ring/radial circuit I have connected a junction box with a cable to a switch then from the switch to the ceiling rose.
Is that OK ? If not why not - I am quite technically minded and cannot see why this wouldnt work but if there is anyone qualified to tell me differently I would appreciate it.
Cheers.
Scott
Well, it does work, if connected correctly :lol:
Thats the older way of doing things, before three plate ceiling roses came about.
With the new method, you have less connections, and the connections you do have are always accessible - ideal for fault finding!
BUT
With the increase in popularity of downlights, wall lights and fancy centre lights, even the three-plate rose method is beginning to show it's age. It is now more popular to wire the circuit by looping in and out of the light switches, leaving a single cable, or possible just two cables at a lighting point.
All ways work, all ways comply, the JB method just uses more materials, more labour intensive, and you end up with more joints to go wrong and get lost.
Cheers.
Scott
Yes it`s OK .
However thiswould mean connecting the nuetrals in a strip connector if a single pole switch is used.The connector "should" be secired in the box out of harms way (but often it isn`t).
anternatively if you use a DP switch then OK
