can i get a hose connector for kitchen tap ?????
Assuming your tap has an internal thread, then Hozelock do an adapter that screws into your tap, which then allows their hose connectors to fit your tap.
B&Q sell Hozelock products, as does ebay.
TBH unless its a normal old fashion tap. i have yet to find a hose connector that will stay on.
Your tap has an angle, the "clamp on" style connectors have an awful habbit of slipping.
I would suggest you fit an outside tap (following water regs)
useless but true: If you have a non electric shower you can undo the actual shower from the pipe, put a 1/2 inch compression connection on the shower pipe (hand tight) from the other end have a 15mm pipe with either a hose connector or the actual hose. But dont drop it as the connector my damage the bath. It really does work, i have to do this at my mum's if i need a hose
