I Note that you haven't actually put any sizes in your post. You may find that your new roof at the steeper angle effectively disables your ability to p d a dormer anyway. Dormers are not permitted if
the cubic content of the resulting roof space would exceed the cubic content of the original roof space by more than -
(i) 40 cubic metres in the case of a terrace house, or
(ii) 50 cubic metres in any other case
For the purposes of Class B “resulting roof space” means the roof space as enlarged, taking into account any enlargement to the original roof space, whether permitted by this Class or not
Assuming your house is detached.. If making your roof 45 degrees increases its volume by 50 cube or more, you're knackered. If it doesn't then it certainly eats into your allowance, so if your new roof adds 30 cube you can only add dormers which increase it by 20 cube
As an example, a7x7 house of 35 degrees roof has a roof volume of 60 cube, at 45 this rises to 85cube limiting the dormer volume to 25 cube. This would still be sufficient to do a 2x2 dormer right the way across the roof.. But we've no idea how big your roof is, and 7x7 is a small house
Hi Cjard, I hope to be working from the premise that the local authority assume that the roof has always been at 45 degrees, after all they have passed 2 sets of plans over the last ten years that show a 45 degree roof with a house footprint of 11 metres by 7 metres. I do understand that I can only add 50 cubic metres and I expect to be inside that. What I don't fully understand is - is it 50 cubic meteres of usable space or does the allowance include the unusable space behind what will be the loft internal walls?
