Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
if you increase the pressure it will squirt and spray more
If you want it to splash less, you should reduce the flow. A ball-o-fix isolator will do this, partially closed. Or you could clean or replace or remove the aerator in the nozzle of the tap
You might improve the flow if the main water pipe is small by putting in a bigger one. It will have to go right the way to the side of the road.
