can i increase not water pressure on condenser boiler?
  • Thread starter Thread starter snadge
  • Start date Start date
S
snadge
i wish to try and increase the hot water pressure to see if i can increase the flow to stop the hot water splashing all over the new oak worktop
its an IDEAL ISAR HE30
thnx
if you increase the pressure it will squirt and spray more
If you want it to splash less, you should reduce the flow. A ball-o-fix isolator will do this, partially closed. Or you could clean or replace or remove the aerator in the nozzle of the tap
You might improve the flow if the main water pipe is small by putting in a bigger one. It will have to go right the way to the side of the road.
