Can I make textured paint
11 Oct 2016
Hi, I have a couple of areas where the emulsion has peeled off part of the wall because the plaster wasn't sealed properly I think.
I want to try to blend the smooth plastered part to the part with several coats of paint.
I'm wondering if I can add a bit of pollyfiller or plasterboard adhesive (because that's what Ive already got) to the paint to achieve that ?
Use filler in the areas of peeled paint and sand down flat to the rest of the paint.
Then paint over the filler.
Failing that, you could use a textured wall paper or lining paper the walls
