- Joined
- 23 May 2013
- Messages
- 1
- Reaction score
- 0
- Country
I am in the process of stripping some wallpaper. Underneath to my luck the wall is coming up very smooth. After stripping the paper I am also wiping with a wet rag with some detergent to get the adhesive off - well more like scrubbing. Some areas are more yellow than others so I am guessing the yellow bits are adhesive and I have been unable to get the adhesive off 100%.
1)Do I need to wet wipe/scrub more vigorously and try to remove the yellow (adhesive?) bits 100%
2)Can I paint straight over the underlying smooth painted surface or do I need to use a primer first?
I am guessing that this underlying paint is from the late 60s or maybe 70s. Just a guess. If I'm wrong then at most from early 80s.
Thank you!
Thank you!
