I have a closed ch system (with a pressure feed/flexible hose; no overflow tank) and am looking to relocate a radiator (due to knocking out central plasterboard wall between toilet and bathroom). Would like to replace existing radiator with heated towel rail and relocate on far wall. Because I will be cutting the pipes and extending, I am assuming I will have to drain the system. I can't find any information on how to do this for a closed system. I can drain all the rads and the inverted loops (after letting the water cool and turning off the pump), but can I just refill from the pressure feed from the water tank? Does the system not use some sort of additive in the water? Any help or link to explanatory site much appreciated
