- Joined
- 21 Sep 2024
- Messages
- 19
- Reaction score
- 0
- Country
I'm going to put two 20w extractor fans into a dry attic space to ventilate it as it gets very hot in summer due to all of the insulation that the government forced us to install for the winter.
I'm planning to connect them to a smart Fused spur so that I can turn it on and off remotely via home assistant and a wireless temperature sensor.
can I run them both off of a single spur, or do need two. the math says that the base load is well within the limits, but us there some other reason I'd need to seperate them.
The spur is
the extractor fans are
The spur is
| Specification | |
| Brand | Manrose |
| Building Regulations | Will comply with Building Regulation Part F if installed in accordance with the manufacturer's instructions and by a competent person. |
| Construction Material (Heating) | ABS Plastic |
| Domestic/Commercial Use | Suitable for Domestic & Commercial Use |
| Ducting Diameter | 100 mm |
| Ducting Included | Ducting Not Included |
| Extraction Band | 201-300 m³/hr |
| Extraction Rate | 245 m³/hr |
| Extractor Fan Control Type | Standard |
| Fan Diameter | 100 mm |
| Fan Operation Type | Mains Wired |
| Fan Speed Settings | 2-Speed |
| Fitting Installation | Mount in Loft or Ceiling Void |
| Fixings Supplied | Fixings Supplied |
| IP Rating | IPX4 |
| Manufacturer Guarantee | 3 Year Manufacturer's Guarantee (T&Cs Apply) |
| Model Name/No | MF100 |
| Noise Level at 3m | 24 dBA |
| Overload Protection | Overload Protection |
| Pack Size | 1 |
| Pieces in Pack/Case | 1 |
| Power Consumption | 20 W |
| Power Voltage Supply | 240 V |
| Product Depth | 298 mm |
| Product Height | 230 mm |
| Product Type | Mixed Flow Fan |
| Product Width | 175 mm |
