I assumed Network Video Recorder - although I'm sure there are other possibilities.What is a NVR?
Indeed, either could be - so your question is irrelevantWhich? Either could be quite a large load.
You REALLY should get out moreWhat is a NVR?
oohhhhhhhhh I thought it may have been no volt release... but why anyone would want one for a water heater is beyond me... on second thoughts: https://www.diynot.com/diy/threads/shower-isolator.595585/I assumed Network Video Recorder - although I'm sure there are other possibilities.
I confess that was my very first thought, but I then realised that Network Video Recorder would sit far more sensibly alongside Modem and PC Monitor than would 'No Volt Release'!oohhhhhhhhh I thought it may have been no volt release...
So does anyone actually know? TTW, how does getting out more help?I confess that was my very first thought, but I then realised that Network Video Recorder would sit far more sensibly alongside Modem and PC Monitor than would 'No Volt Release'!
Kind Regards, John
Thanks.![]()
Network video recorder - Wikipedia
en.wikipedia.org
Thanks Harry.Modem would be OK, plus maybe the NVR and monitor, but the vacuum is not a good idea mixed with the other items. There might be nuisance tripping.
You mentioned a bungalow - usually solid floored bungalows have the sockets wiring in and down from the loft. Have you checked? If that is the case you could spur off the socket circuits.
Lighting will definitely be wired in the loft, so there will certainly be an accessible L and N in the loft for the lighting circuit(s), perfectly able to supply a modem, NVR and a monitor, though not a vacuum cleaner.
Here Here. Let's not bully Winnie.You REALLY should get out more
Who is this wonderful third person ?Because he is a useful source of information and should be respected.
@ban-all-shedsWho is this wonderful third person ?
Why not when most of what whinny does is bully those offering sensible and correct adviceLet's not bully Winnie.
Yes I agree, those on here who are a useful source of information should be respected. Who are you proposing in your post, you didn't give us any idea whosoever you are describing.Because he is a useful source of information and should be respected.
