Hi
I have a question which I would like to ask.
I have a mains powered air compressor which is housed inside its own concrete cupboard built onto the rear of my garage.
The air compressor will be powered from a dedicated circuit running from the consumer unit in the garage into the cupboard.
I have to switch the compressor on and off on the compressor itself.
What I would like to do is have a neon indicator fitted inside the garage as a reminder to me that the air compressor is still switched on so that I remember to switch it off at the compressor at the end of the day.
Could I use a neon indicator to do this ? If I understand it correctly the indicator to be connected between L and SL.
Any help would be greatly appreciated.
