can I use an immersion timer as a light switch?
13 Jan 2013
Yorkshire
Hi
I have a new immersion heater timer switch which i want to use to switch my living rooms lights off and on whilst on holiday.
The wiring diagram says . 1-Neutral from mains . 2- live from mains , 3-Neutral output to appliance, 4-Live output to appliance.
The lighting switch which is fitted at the moment has two wires , live and neutral.
Can the immersion heater switch be wired to use this to switch my lights off and on please. If so how do i wire the switch.
Thank you for any advise.
Anything is possible but not advisable.
Get a plug in timer and some lamps.
Ditto. Your switch does NOT have a neutral. It has a switched live which hasn't been correctly sleeved.
Do what EFLImpudence suggested. That's what I do.
Hi thank you
I will return the switch and buy normal switch timers.
Many thank for your quick repys and advise
Thank you all for the good advise, ive now purchase plug in timers from Tool store .These seem quite robust and easy to use.
Many thanks everyone for helping out
