can i use the cans of freeze spray?
Hell if you are going to attempt that one live mate, you're a braver man than me.....at least have other taps on the same feed running full bore to reduce the pressure.
It sounds like you're fed with black alkathene....where does the MDPE come in?
John :)
Im just running out of options!
I tbought it was mdpe but looks like its alkathene.
Its rock solid and very very rigid so dont think it will clamp! And there are no other taps on that feed. The inside house taps are on a seperate feed (which i can knock off but dowsnt affect the outside tap)
This is the pipe. Has writinv on it but means nothing to me!
It has an external circumfrence of 56mm (external diameter 17.79mm)
